TwinTurbo.NET: Nissan 300ZX forum - Re: help, timing belt gear removal
Subject Re: help, timing belt gear removal
Posted by Da Flash on May 01, 2009 at 10:02 PM
  This message has been viewed 164 times.
In Reply To help, timing belt gear removal posted by mongooze on April 29, 2009 at 07:13 PM
Message :Trying to take my crank off and the timing belt gear pulley that sits on the crank before the oil pump will not come out. I tried heating it, wacking it with chisels etc. any have this problem? any ideas?
I just did this the other day, the "cutting it above the keyway with a dremel method" worked great! by the time you drill and tap holes for the gear puller method, you could've cut and chiseled it off. You just have to be careful not to damage the snout, key, or oil pump.
